Overture PLA Professional settings?
dclaar
(@dclaar)
Has anyone used Overture PLA Professional? Is there a good preset?
If not, they recommend:
  • Recommended Extrusion/Nozzle Temp:  190 °C - 220°C (374℉~ 428℉ ),
  • Heated Bed Temp:  40°C - 60 °C (104℉~ 140℉)
  • Printing Speed:40~70 mm/s
On the "Filament Settings" tab, I can set nozzle & bed temps, and apparently use a different value for the first layer.
On the "Print Settings" tab, under Speed, there's an overwhelming number of speeds, from 25mm/sec to 200 mm/sec.
What's the best way forward?
Opublikowany : 20/03/2022 12:02 am
jsw
 jsw
(@jsw)
RE: Overture PLA Professional settings?
I have not used the 'Pro' version, but most of the parameters seem like right in the ballpark for generic PLA.
The generic PLA infill speed is 80, and you might bump that down to 70 to be strictly within specs.
You can also try one of those 'temperature tower' prints to get an idea what nozzle temperature works best with that particular filament.
Opublikowany : 20/03/2022 1:00 am
1 ludzie polubili
Given their recommended range, you're probably good with the generic PLA profile. I'd run a hollowed out calibration cube to calibrate the extrusion multiplier. See https://projects.ttlexceeded.com/3dprinting_prusaslicer_extrusion_multiplier.html#wall-thickness-in-prusaslicer (I usually do a two perimeter wall)
Opublikowany : 20/03/2022 12:27 pm
1 ludzie polubili
dclaar
(@dclaar)
Thanks, it works great with the Prusa PLA settings (which don't seem to be that different from others, e.g. Amazon Basics or generic).
Opublikowany : 21/03/2022 4:03 am
Tito
 Tito
(@tito-2)
I am having a lot of trouble with it.
Opublikowany : 01/09/2022 6:44 pm
Huntinherrington
(@huntinherrington)
I use prusa pla settings in prusa slicer.
Printed a 47 hr print on my very first print after printing a couple of the prints with Prusament that come on the sd card. Swapped to the Overture PLA+ and started printing.
I bought the printer assembled and did not adjust anything,
It prints great. No issues.
Nozzle 215
Bed 60
Every speed settings I have selected have been good
This post was modified 4 years temu 2 times by Huntinherrington
Opublikowany : 13/09/2022 8:41 am
Stacy Boles
(@stacy-boles)
Yes, I am also have a huge problem with the regular Overture PLA and PLA professional (will not stick to the bed at all!) , but at the same time I am have perfect prints with the Overture Matte and Overture Cream.
Opublikowany : 07/04/2024 7:36 am
Tincantantan
(@tincantantan)
What should my infill speeds be with the regular pla
Opublikowany : 06/06/2024 2:55 pm
Amir S.
(@amir-s)
I'm having similar issues with bed adhesion with the PLA Professional vs. the older PLA Matte and PLA ECO, all from Overture.
Did anyone figure out good settings? It's disappointing that they don't just provide filament profiles for each of their material types.
Opublikowany : 30/09/2024 6:17 pm
HandyObviousTank
(@handyobvioustank)
Just did my first print w/ Overture Pla Pro and it was not sticking at all on the PET side of my magnetic build plate, might as well have been teflon. Flipped it to the PEI side and it adhered fine.
Opublikowany : 02/12/2024 3:11 pm
