Overhang threshold backwards in latest Slic3r PE?
Chris Finlay
(@chris-finlay)
Forgive me if I'm being an idiot and misreading the tooltip.
In previous versions of Slic3r, the overhang threshold was set to 45 degrees - so midway between the horizontal and vertical. The universally accepted standard limit for printing without supports, from what I understand. However, after updating to 1.41.0, I noticed that the default overhang threshold was set to 55 degrees. I was a little stunned, but I figured if the latest firmware update and the slicer update would allow slightly more extreme overhangs on prints, then ace - less support the better!
HOWEVER after reading the tooltip, I was a little confused. The tooltip states that in Slic3r, 90 degrees = vertical. So therefore the new default setting of 55 degrees is actually closer to vertical, meaning that less extreme overhangs will need support. I've made a quick mockup in F360 of what I mean as I tend to not explain myself well. On both diagrams, the dashed line is at 45 degrees, the previous default and midway between horizontal and vertical. On the left is what I had assumed was the new default threshold, at 55 degrees from vertical. On the right is what is actually implied by the tooltip - 55 degrees from horizontal (degree value increases as you move toward vertical), and a less extreme overhang that would generate support material.
Publié : 25/09/2018 12:53 am
Re: Overhang threshold backwards in latest Slic3r PE?
You can change it to whatever works. I'd just experiment and see. I tend to tweak it for every model. I still have to set it absurdly high (90%) to get a bit of support for filleted curves. I can only think that Prusa has gone with a conservative starting value to help newcomers unfamiliar with the settings have better chances of success. I don't think anything's mechanically changed with the printer or the way Slic3r works. This goes back a few versions at least.
I've noticed Prusa scaling back some of the presets recently. They started out very aggressively -- too aggressively perhaps -- in early profiles. I suspect they're easing back in the interests of avoiding "I tried Prusa's preset and it didn't work" support issues. You can still change the pre-sets once you know that you're doing.
Publié : 25/09/2018 2:53 am
Phil
 Phil
(@phil-4)
yes, it took me awhile to realize this, but it is backwards from Cura. 90 degrees in Slic3r is 0 degrees in Cura.
Publié : 25/09/2018 3:40 am
Area51
(@area51)
Membre
I agree - it is backwards. Had the same experience as chris... Changed it back from 55 to 45 degree as I seldom have problems with 45 degree overhang.
Publié : 25/09/2018 3:55 am
Chris Finlay
(@chris-finlay)
Ok, thanks for confirming I wasn't either going mad or being an idiot 😀
I put it back to 45 degrees after installing anyway, as that's never given me any issues. I have some half-decent support settings dialled in so I made a backup of them prior to updating.
Publié : 25/09/2018 9:39 am
