Nozzle temp reads 300 with no power on nozzle
gorillamotors
(@gorillamotors)
I just turned on my MK3S+ and the nozzle reads 300 with no power to the nozzle. I replaced the thermister with a new one and it still reads 300. Any clues?
This topic was modified 2 years temu by gorillamotors
Opublikowany : 03/05/2024 2:45 pm
BigToeDaddyO
(@bigtoedaddyo)
Go buy some tin filament quick!  You have a 3D printer that can print metal!
Seriously…
300 sounds like to top limit of the range, so maybe a floating (not connected) thermistor
Maybe a hardware error? (bad IC, loose/damaged/wrong location of the connection on the control board)
Maybe the firmware is bad/corrupt? (Re-flash, but not a lot of confidence in this solution/debug step)
This post was modified 2 years temu by BigToeDaddyO
Opublikowany : 05/05/2024 4:25 pm
