Nozzle temp reads 300 with no power on nozzle
I just turned on my MK3S+ and the nozzle reads 300 with no power to the nozzle. I replaced the thermister with a new one and it still reads 300. Any clues?
Questa discussione è stata modificata 2 years fa da gorillamotors
Postato : 03/05/2024 2:45 pm
Go buy some tin filament quick! You have a 3D printer that can print metal!
Seriously…
300 sounds like to top limit of the range, so maybe a floating (not connected) thermistor
Maybe a hardware error? (bad IC, loose/damaged/wrong location of the connection on the control board)
Maybe the firmware is bad/corrupt? (Re-flash, but not a lot of confidence in this solution/debug step)
Questo post è stato modificato 2 years fa da BigToeDaddyO
Postato : 05/05/2024 4:25 pm
