No LOAD option in menu
wswartz
(@wswartz)
In the menu options of my MK3S+, the LOAD option no longer appears in the list.  I can Unload filament, and I can load filament manually using the Settings->Move Axis->Extruder option.  What might the issue be here?
Thanks...
Posted : 20/08/2024 2:34 pm
Eef
 Eef
(@eef)
RE: No LOAD option in menu
Could it be the filament sensor is set to autoload?
just push in the filament. And if all Ok it will ask set type of filament.
if not go into settings, disable filament sensor. You should now have the LOAD option in menu
Posted : 21/08/2024 2:08 pm
