RE: Newbie to Prusament PETG Question with Pic?
Your Live Z setting is way too low, causing the already-extruded plastic to be pushed around and form humps.
Even with a good setting, you'll see some of that sort of look, but it won't be so much as to interfere with the layers above.
Publié : 05/05/2020 3:48 pm
Topic starter
answered:
Ok I will adjust higher. When I had it up higher I was having trouble with bed adhesion even after cleaning with alcohol.
Publié : 05/05/2020 3:55 pm
To help with adhesion, a good wash with hot water and disk soap will help. Be sure to dry afterward to avoid rust and only touch the edges of the build plate.
Publié : 05/05/2020 5:17 pm
Topic starter
answered:
@area51
Thanks will give it a try.
Publié : 05/05/2020 5:45 pm
