New MK3S+ kit build, Unable to start selftest
Paul Gray
(@paul-gray)
I have just completed the kit build of MK3S+. when I turn on the power the unit powers on and the LCD asks fo language selection.
I select English and the LCD displays 'Original Prusa i3 Press Research', the extruder fan spins up also. after 2 to 4 seconds the LCD defaults back to language selection, I have tried this start up with the supplied SD card inserted and removed, but the same result the LCD defaults back to language selection every time.
any suggestions what I can do next?
Napsal : 28/03/2021 12:03 pm
kantaki
(@kantaki)
RE: New MK3S+ kit build, Unable to start selftest
I suspect you press the button with X to select the self-test, but this leads to a reset. Confirm by pressing the rotary button.
Napsal : 28/03/2021 12:21 pm
1 lidem se líbí
Paul Gray
(@paul-gray)
@kantaki
Thank you, that's exactly it, it's always the simple things. 🙂
Napsal : 28/03/2021 1:23 pm
