New MK3 Build Einsy Enclosure Problem
Bigdogbro1
(@bigdogbro1)
Hi All,
I purchased a new MK3 for us to use at work and have been assembling it without much drama.
The biggest headache was the assembly of the Einsy controller board enclosure and the swing close cover. All is mounted as it should as far as I can tell but it will not fit like my home MK3 from 2/2018. If I mount the box flush to the outside of the MK3 frame then the door will not close and overlap the box at the hinge side.
Don't know what's going on.
Do you have any idea?
Thanks
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Respondido : 23/08/2018 8:36 pm
RufusClupea
(@rufusclupea)
Re: New MK3 Build Einsy Enclosure Problem
This problem was very recently posted in the Assembly and first prints troubleshooting topic:
RAMBo cover door (can't close?)
That's "MISTER Old Fart" to you!
Respondido : 24/08/2018 12:14 am
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
thanks for the feedback, can you please check if you have any version written on the door and base?
It should be "B6" or something similar.
Can you please also take the photo of the plastic bag, from which you took the printed RAMBo cover parts? I'm interested in the label.
Assembly manuals
/ Knowledge Base
Respondido : 24/08/2018 2:36 pm
Bigdogbro1
(@bigdogbro1)
No revision level on door. The bag picture and other information is at the link listed above in order to keep this problem on one thread.
Thanks Jakub.d
Respondido : 24/08/2018 8:34 pm
