name tags in two colors
ggeh
 ggeh
(@ggeh)
Hi Everyone
When I received my MK3 it came with a name tag with orange background and black print. Can anyone tell me how I can make a name tag like that in two different colors?
Thanks, Gary
Publié : 11/01/2021 9:16 pm
JustMe3D
(@justme3d)
RE: name tags in two colors
Add a pause command at the required height by using the vertical slider in the Prusa Slicer, once you have loaded the object into the slicer and generated gcode. Go to the tab showing the sliced object, slide the orange slider downwards to the required height of the object, watch the object disintegrating layer by layer. Then click on the slider - I think its a right-click -, add a pause and slice again. Then export and print. When the printer pauses, change filament and resume print.
Publié : 11/01/2021 10:31 pm
Holck
(@holck)
You add a color change, not a pause, but otherwise correct. its just a left click on the plus sign.
Here is an ok video:
Publié : 11/01/2021 10:37 pm
1 personnes ont aimé
Here's an example of a manual filament swap at a certain height:
https://www.prusaprinters.org/prints/50534-prusa-signs-for-lack-enclosure
Or you can use the technique in here, for a two-color model that doesn't require the use of an MMU. If the accent color part is only 3 or 4 layers high, it's a manageable number of manual filament changes.
https://www.prusaprinters.org/prints/51471-dual-color-lcd-cover-for-mk3s-no-mmu-required
Publié : 11/01/2021 11:02 pm
ggeh
 ggeh
(@ggeh)
Hi everyone
I just drew up a quick name tag and I'm printing it now. I have to wait and see if i did this correctly. If it turns out Ill post a picture.
Thank you all for your quick and in depth response, You all are fantastic,
Thanks,Gary
Publié : 12/01/2021 12:08 am
ggeh
 ggeh
(@ggeh)
It worked my first two color print. Thank you all for showing me how to accomplish this.
Thanks Gary
Publié : 12/01/2021 2:19 am
ggeh
 ggeh
(@ggeh)
Publié : 12/01/2021 2:23 am
