My extruder gears are squeeking during extrusion
dimprov
(@dimprov)
Not sure why exactly. It sounds like they are squeeking against plastic, so I suppose they might be squeeking against the filament. FWIW, the print speed is set in the slicer at 300mm/sec (I'm using a volcano), so I'm not sure whether that has anything to do with it or not.
Anyone else encountered this?
Veröffentlicht : 27/05/2018 11:00 pm
Tiago
(@tiago)
Re: My extruder gears are squeeking during extrusion
I saw your post with volcano print, so i guess you using 0.89mm extrusion and 0.3mm layers?
If so is more than normal, your extruder is skiping because you are far higher than the volcano limit
300 * 0.3 * 0.89 = 80.1mm^3/s
So you are tring to push 80mm^3/s when the limit is +/-40mm^3/s on volcano (2x more!), as filament cant go through the nozzle at that speed, the noise you hear is the dents from gears eating the plastic and skiping.
Use 150mm/s max at that config and your extruder will be more happy.
Note if you use 150mm/s you will have to increase temperature to ensure plastic melt, if you go a little down like 30mm^3/s you don't need to increase temperatures.
If you use 0.6mm layer height the max speed you can use is 75mm/s for a reference. So always do the math: speed * layer height * extrusion width must be less than 40mm^3/s
Veröffentlicht : 28/05/2018 1:43 am
dimprov
(@dimprov)
So far, through experimentation, I've found that setting the "max volumetric speed" under filament settings in slic3r, it will override all other print settings, apparently with a single speed, which does not work very well, because the infill speed needs to be different than the perimeter speed.
So, if I don't use that, I next need to find what controls the filament speed.
Veröffentlicht : 28/05/2018 8:58 pm
Tiago
(@tiago)
Don't use auto speed, always go manual.
Check filament -> Advanced
Veröffentlicht : 28/05/2018 10:36 pm
dimprov
(@dimprov)
I don't see anything there:
Veröffentlicht : 28/05/2018 11:07 pm
dimprov
(@dimprov)
I seem to have already hit a wall with slic3r, so I just now downloaded simplify3d and will be trying that....
Veröffentlicht : 28/05/2018 11:45 pm
dimprov
(@dimprov)
As near as I can tell from looking at simplify3d, the speed of the filament in the extruder is an imputed value, determined by the program as a function of layer height, layer width, and target print speed. It doesn't seem to be broken out as a separate value. I presume the same is true for the current version of slic3r, which is why I don't see it listed as a separate value.
Apparently, it's incumbent upon the user to not set a faster speed than can be extruded, given the width and height.
Veröffentlicht : 29/05/2018 1:22 am
ScoutStorm
(@scoutstorm)
Bioluminous
I had a strange squeaky noise that I traced to the extruder, especially prevalent when retracting. I discovered that the extruder motor gear was not aligned with the filament. Grub screw was tight, so I apparently forgot to check alignment when building. Once aligned, the squeak went away.
Veröffentlicht : 29/05/2018 2:50 am
Tiago
(@tiago)
Not sure what you are tring to achieve, but as told before there are many limits: Software, firmware, hardware and material. You must ensure a good ecosystem and probably you need to override the firmware (recompile)
Veröffentlicht : 29/05/2018 3:07 am
dimprov
(@dimprov)
In retrospect, maybe I should have gotten the 40w heater cartridge instead of the 30w one. I set a target temperature of 210C for PLA, but during the fast extrusion, the thermistor reports that only 199C can be sustained. Of course, if I slow the extrusion rate down enough, the temperature is then able to catch up.
I re-ran PID autotune, thinking that might be the probem, but the same results.
Veröffentlicht : 29/05/2018 5:03 am
Tiago
(@tiago)
Easy, increase temperature by 10ºc, so print at 220ºc or even 225ºc.
Also use a sock if you not already
Veröffentlicht : 29/05/2018 7:08 am
dimprov
(@dimprov)
I did try setting it at 220C, but I twice got firmware alarms of a "thermal runaway" condition, which shut down the print both times. Go figure.
I'll try the sock.
Veröffentlicht : 29/05/2018 2:24 pm
Tiago
(@tiago)
I'll try the sock.
You can set a more agressive temp compensation at firmware and a higher limit for thermal runaway
Veröffentlicht : 29/05/2018 5:30 pm
