Molten Hot End Heater
Stránka 2 / 2
wreinhold
(@wreinhold)
RE: Molten Hot End Heater
I'm thinking about using a copper heater block vs. the (presumably) aluminum original.  Melting point >1000C vs 660C for aluminum.  https://www.amazon.com/dp/B08NPKF2GC/ref=cm_sw_em_r_mt_dp_HMRB9R9HDR9NT6GZ680W?_encoding=UTF8&psc=1
Any thoughts?
Napsal : 23/04/2022 11:08 am
Before I switched every printer over to a Dragon hotend, I used nickel plated copper blocks. They worked fine. Not that I noticed any appreciable difference, for better or worse.
Napsal : 23/04/2022 1:46 pm
1 lidem se líbí
RandyM9
(@randym9)
I’ve considered installing a nickel plated copper heat block for a variety of reasons but my stock unit works so no urgent need to change right now. And, with the introduction of the E3D Revo Six, this becomes a far less likely proposition for me.
Given your unique situation, I would ‘assume’ you’ll be receiving a new stock heater block, at the very least, under warranty.
I would strive for a solid stock printer working as designed before considering any mods. But that’s just me.
Napsal : 24/04/2022 4:59 am
wreinhold
(@wreinhold)
Posted by: @randym9
Yes, they're sending all the parts to rebuild a brand new extruder assembly along with a replacement Einsy board.
I think that's very rational advice.  Thanks.
Napsal : 24/04/2022 11:26 am
Swiss_Cheese
(@swiss_cheese)
@randym9
This is out of context, but thank you and I do appreciate you.
regards
Swiss_cheese
The Filament Whisperer
Napsal : 28/04/2022 12:21 am
RandyM9
(@randym9)
@swiss_cheese
Mr. Swiss, much appreciated and, likewise.
Cheers
Napsal : 28/04/2022 3:33 am
RandyM9
(@randym9)
Greetings @wreinhold :
If you get a chance, would you mind sharing an update on your rebuild and current printer status? I sincerely hope everything is working as expected at this point.
If you posted this info elsewhere in the forums, please post a link and forgive my missing that.
Cheers
Napsal : 03/08/2022 5:25 am
wreinhold
(@wreinhold)
The rebuild went fine and the printer is back up and running with no issues (and no mods).  Prusa let me know the "Automatic ADC pull-up reset" feature in the 3.11.1-RC1 firmware release is a result of the analysis of the parts I returned.
Napsal : 04/08/2022 1:10 am
1 lidem se líbí
RandyM9
(@randym9)
That’s great news! Good to know Prusa took your event seriously and followed up with you.
Cheers
Posted by: @wreinhold
Napsal : 04/08/2022 3:50 am
towlerg
(@towlerg)
I'm still having trouble with that tiny heater cartridge being able to generate enough heat to melt that lump of metal.
Napsal : 04/08/2022 12:00 pm
RandyM9
(@randym9)
Posted by: @towlerg
Napsal : 04/08/2022 1:23 pm
towlerg
(@towlerg)
I'm very old and don't understand emoji's Shout go blind?
Napsal : 04/08/2022 4:19 pm
RandyM9
(@randym9)
Lol, sorry, laughing at your comment:
“I'm still having trouble with that tiny heater cartridge being able to generate enough heat to melt that lump of metal.”
Then hiding my eyes at the thought of that actually happening!
Cheers
Napsal : 05/08/2022 3:36 am
Stránka 2 / 2
