MK3S optical filament sensor issue
HackMonkey
(@hackmonkey-2)
Got the MK3S upgrade installed. The sensor works, but it seems the inlet hole is too sloppy. When I insert filament the status flashes from 0 to 1 and back quickly. If I press on the side of the filament, and force it towards the ball, it will trigger. But letting off pressure will not. It does trigger the autoload sequence, and will start a print, but unloads seconds into the print.
Seems like the hole is either too large, or the finger inside is too small.
Napsal : 01/04/2019 11:15 pm
JMcK
 JMcK
(@jmck)
Re: MK3S optical filament sensor issue
😯 :mrgreen:
When someone asks you if you're a god, you say, "YES!"
Napsal : 02/04/2019 12:02 am
