MK3S loosing position on the Y axis when new print begins
sberesfo
(@sberesfo)
Hi, Our MK3S is updated to the latest firmware 3.14.1-8237. Once we get the printer started on a print it works great. The Y axis is getting messed up during the mesh bed leveling. We have successfully calibrated the XYZ each time this happens and the problem comes back after one or two successful prints. The current print is working fine but the purge line was about an inch away from where it should be.
Can someone please tell us a few things we can try to do the correct or further troubleshoot this problem? Thank you, Scott
Opublikowany : 03/05/2025 5:11 pm
sberesfo
(@sberesfo)
RE: MK3S loosing position on the Y axis when new print begins MORE INFO
I have more detailed information about this problem. Today, after a successful print, I tried the Auto Home from the Calibration menu. We tried a dozen times to Auto Home but it would not move in the Y to go towards home. We rebooted the printer and tried to manually move the Y axis but it would not move closer to home. We tried the Auto Home a few more times before it finally went home.
Does anyone have any suggestions?
Opublikowany : 05/05/2025 1:12 am
