MK3S firmware on MK3 printer
Hello, i am starting to use octoprint with my mk3s. i am not sure, what i changed, but now the display of my prusa says something like "mk3s firmware used with mk3 printer". Does anybody know, where this comes from? I already flashed the current firmware 3.8.1.
And also i now does strange thinks like driving the printer head to the upper left corner.
Any help is welcome.
kind regards,
Matt
RE: MK3S firmware on MK3 printer
Are you sure you have a Mk3S? sounds like the firmware detected the old optical IR sensor and thinks you have a Mk3. If so, you flashed the wrong firmware and need to flash the Mk3 (Not S) firmware
You most likely flashed with the S firmware.
You may have issues with Octoprint when connecting or starting a print but it will continue to function properly except for the message on the info screen.
