Min temp fixed restart
Out2sea71
(@out2sea71)
Hello all, I have gone through many posts about swapping the thermistor or having a broken wire.  I waited a week and have a new thermistor installed but have the same error.  I don’t have any other symptoms that I can see but the printer stops within a few minutes or after 45 minutes with this error.  What else can it be?
Posted : 13/04/2020 11:00 pm
lee.g
(@lee-g)
RE: Min temp fixed restart
This is potentially the part cooling fan blowing air onto the centre of the bed or your nozzle.
To confirm can you start one of the prints that will fail after a few minutes and watch the temps on the screen.  Depending on what material and settings you are using the fan will kick in after the first layer is complete.  Normally the bed and nozzle temp will bump up after the first layer is complete again depending on print material and settings used.
What you are looking for is whether the bed, hotend or both are not getting to temperature.
Posted : 14/04/2020 6:36 am
