maximum printable size
the manual says maximum printable size is 21x21 for the mk3s. when i try to print a more large object say 22x22 ex skirt it still prints very nice. why say 21x21cm when it can prints bigger sizes. is it because the printer functions best within those regions?
RE: maximum printable size
Hi Jimmy,
the Prusa shop says
Mk3S - BASIC FEATURES
- Great build volume – 11,025 cm3 (25 x 21 x 21 cm or 9,84 x 8,3 x 8,3 in) (X×Y×Z)
so the
max width is 250mm -
Max Depth is 210mm -
Max Height is 210 mm -Don't forget about the skirt, if the model is close to max volume, the skirt will not fit on the build plate
@joantabb
ah thanks for your reply. now i get it 😊
Glad I could help.
