Loud fan noise upon start up - is this normal?
Stránka 1 / 2
mgtarallo
(@mgtarallo)
Hi guys - just wondering - when I turn on my Prusa i3 MK3s - the cooling fan on the extruder makes a lound whining noise upon start up and then it idles down to what I assume is normal. Has anyone else heard this?
Thanks
Napsal : 24/02/2020 7:26 pm
1 lidem se líbí
RE: Loud fan noise upon start up - is this normal?
I have had this on old fans, as they wear out,
It is  often possible to unscrew the fan, partially remove the label in the centre of the back of the fan, add a little light oil, replace the label, and re fix the fan, then you will probably have a quiet life, whilst you order a replacement fan... the bearing will eventually wear out, but by that time you should be prepared with a spare fan.
Napsal : 25/02/2020 1:22 am
1 lidem se líbí
Mike Daneman
(@mike-daneman)
Yes, this is normal.
Napsal : 25/02/2020 6:20 am
Area51
(@area51)
Most cooling fans has sliding bronze bearings and they tend to dry out as Joan describes - the drop of thin sewing machine oil fixes the problem for a long time. Has been using that solution on worn out computer fans for over a decade.
Napsal : 26/02/2020 9:11 am
1 lidem se líbí
Chocki
(@chocki)
I have a bottle of singer sewing machine oil and a precision oiler which I use for the bearings and fan bearing.
I've done the fan 3 times in a year so far, and I apply a drop of oil onto the steel rods before every long print or before a few short prints, then wipe off the excess and dust from the ends of the rods where it collects.
Napsal : 26/02/2020 12:51 pm
mgtarallo
(@mgtarallo)
Thank you all - So just for reference this is a bran new unit. One post says it is "normal" - I will send to support and see what they say as well.
Napsal : 26/02/2020 5:28 pm
Sembazuru
(@sembazuru)
It depends on the sound. If the "loud" noise is just the sound of rushing air it is normal as both fans are spun up to 100% briefly as part of the systems POST (Power On Self Test). Because nothing else is happening, it is likely that your room is very quiet at that point so it sounds louder than when printing. If you are convinced that the rushing air sound is louder than normal, check to make sure that the fan blades (on both fans) don't have an accumulation of dust on them.
But if the noise is something other than rushing air you may be having problems.
See my (limited) designs on:
Napsal : 26/02/2020 10:16 pm
mgtarallo
(@mgtarallo)
OK thanks again all - here is a link to a video so you can hear the noise for yourselves:
Napsal : 26/02/2020 10:42 pm
Mike Daneman
(@mike-daneman)
@mgtarallo
The fan spinning fast for a little while when you turn on or reset the printer is normal (that's what I meant when I said "this is normal" before).  The fan spins fast for about a second and then turns off. I think that's the printer's way to saying "I've been reset."
However, yours sounds like the fan may be scraping against something.  Do you get a similar "scraping" sound when the fan turns on during printing (if you just turn it on through the LCD settings menu)?  You may want to check if anything is blocking the fan blades.
Napsal : 27/02/2020 7:08 am
mgtarallo
(@mgtarallo)
Just an update for all of those that stumble on this post - the noise occurred at high speed on startup test - prusa support told me to loosen the 4 screws around the fan - and that solved it. The housing must have been too tight.
Napsal : 10/03/2020 9:06 pm
4 lidem se líbí
Graham
(@graham-2)
@mgtarallo
i have noise and have not yet found it, I may try that fix
thanks for that
Napsal : 21/05/2020 9:03 pm
Lars Clausen
(@lars-clausen)
@mgtarallo
Thanks for this tip! While I was unable to replicate the loud fan noise using M106 commands, loosening the screws a bit indeed made it much more tolerable.
-Lars
Napsal : 06/06/2020 1:11 pm
Lars Clausen
(@lars-clausen)
Scratch that. On my next print, the fan was back to the normal noise level. It's only while doing the _second_ layer, though.
Napsal : 06/06/2020 6:17 pm
pcweber
(@pcweber)
Get back with support, this fan is supposed to be really quiet, it's supposed to be a premium part; therefore, if the machine is new then Prusa would have to replace it. That loud noise is not normal for a new fan. It does sound as if the blades are hitting against something. You can crank up the fans in the setting menu under temperature.
Phil
Stay safe and healthy, Phil
Napsal : 06/06/2020 6:25 pm
mgtarallo
(@mgtarallo)
 Thanks all - mine is back to doing the same noise again - i think the fan may need to be replaced. I will send this thread to support.
Napsal : 06/06/2020 8:59 pm
pcweber
(@pcweber)
I just re-reviewed your video and comparing it to my startup noises feel that your noise is like mine, not coming from the extruder fan but coming from the nozzle fan. I ended up with an error sometime after mine started making the noise and luckily had on hand a replacement. These aren't expensive items and are easily replaced. The next failure I plan to put an xh connector on the cable and fan to avoid, unnecessarily, tearing down the cabling.
Napsal : 27/10/2020 10:37 am
Lars Clausen
(@lars-clausen)
I got a new nozzle fan under warranty - Prusa agreed that it was not working as intended, esp. as it ran much quieter at 100%. The most likely explanation is that I lost a ball from the ball bearing. Due to other commitments (and as Phil says, the annoyance of tearing down the cabling) I have not replaced it yet, so I can tell if the replacement helped.
To check if it's just the normal startup sound, you can run the fan manually at 100% and compare.
-Lars
Napsal : 28/10/2020 8:45 pm
pcweber
(@pcweber)
Lars,
I did the same thing, got one under warranty, eventually I got a fan error and replaced the unit. Like you've said it's annoying but not worth the teardown, but if the fan fails during a long print?
Good luck and keep safe.
Napsal : 28/10/2020 10:21 pm
Lars Clausen
(@lars-clausen)
I'm not sure how to parse that response. The fan makes no noise when I turn the printer on, only during print, and only for a while after the fan starts (second layer). I can't tell now if this happened more or less during the first prints with this printer.
-Lars
Napsal : 31/10/2020 9:07 am
pcweber
(@pcweber)
You need to check for filament strings in the fan unit. In absence of obstruction you might consider having a spare on hand. If the printer is under guarantee make a video and contact tech support.
Napsal : 01/11/2020 7:11 am
Stránka 1 / 2
