Linear Advance Calibration question
buckeyestargazer
(@buckeyestargazer)
I'm trying to tune my MK3 as well as I can, and am working on Linear Advance calibration.  I've used the Marlin K factor calibration pattern to determine the K factor.  The problem is I'm not sure where to enter this number in the gcode.  Here's what I have under Filament Settings/Custom G-code/Start G-code:
M900 K{if printer_notes=~/.*PRINTER_MODEL_MINI.*/ and nozzle_diameter[0]==0.6}0.12{elsif printer_notes=~/.*PRINTER_MODEL_MINI.*/}0.2{elsif nozzle_diameter[0]==0.6}0.05{else}0.12{endif} ; Filament gcode LA 1.5
{if printer_notes=~/.*PRINTER_MODEL_MINI.*/};{elsif printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}M900 K200{elsif nozzle_diameter[0]==0.6}M900 K24{else}M900 K45{endif} ; Filament gcode LA 1.0
Where do I put the K factor I determined?   Does the above G-code look right?  I'm not sure why "PRINTER_MODEL_MINI" is in the gcode when I'm using an MK3.
Best Answer by karl-herbert:
@buckeyestargazer
You must of course enter the values you have determined, in your case the value 50 (for each filament separately) and put a semicolon in front of the Prusa original text (;).
Once you have generated the gcode by the slicer, you can check the value with a text editor. It should then say: M900 K50
Also check if the value in the gcode does not occur twice and is possibly overwritten.
For all editing work I would recommend the free notepad++.
Publié : 04/10/2020 7:02 pm
RE: Linear Advance Calibration question
Posted by: @buckeyestargazer
If you only work with MK3 it is sufficient to define the K value in the filament settings, in this case for LA1.0/1.5 directly without query (if) e.g. M900 Kxx.
Publié : 04/10/2020 8:25 pm
buckeyestargazer
(@buckeyestargazer)
Posted by: @karl-herbert
Sorry, but I need the "for dummies" version of what you are saying.  Should I just copy the gcode in your image and replace the K value with my calibrated value (50)?
Publié : 04/10/2020 8:36 pm
@buckeyestargazer
Publié : 04/10/2020 9:04 pm
