Lifetime of heating element and thermistor
Jára
(@jara-2)
Mitglied
Hi guys, I've had an í3 mk3 for about 3 years, everything was fine until firmware 3.11.0, and since then there have only been problems, clogging, skipping of the feed wheels. I have set the temperature to 215/60 and after the first layer of 210/60, the fan spins so fast that it cools the nozzle to 198 degrees, it reports a temperature exception. The nozzle heats up again and the message is gone and then everything is fine, but now it does the same thing again: I have set 210/60 and the wheels skip, but when I raise the temperature to 215 It doesn't work. It used to work with the same filament and others without any problems. That's why I want to ask if the heating element or the thermistor is bad. When the print is finished, the temperature rises from 210 to 225. Thanks in advance
Veröffentlicht : 30/11/2023 9:39 am
