LCD Screen Print Times, Which Is It?
TitanPrinter
(@titanprinter)
Loving my MK3 so far, using it a ton (my statistics say Total filament used: 688.54m Total print time: 34d:15h) and I've not had a single failed print (other than where it was clearly user error).
On to my question. At the end of my prints I see two print times (see below image for this example). On this example, one says 15:43 while the scrolling screen says 13 hours 46 minutes, does anyone know what these two times represent?
Thanks!
Napsal : 16/05/2018 3:56 pm
Knickohr
(@knickohr)
Member Moderator
Re: LCD Screen Print Times, Which Is It?
The scrolling screen, lower line, is the real print time. The other is the time since you have started the print.
Thomas
Napsal : 16/05/2018 4:05 pm
TitanPrinter
(@titanprinter)
Thanks for the response!
So, this may mean it was extruding for 13:46:00 but total print time was 15:43:00. Would that mean the extra 2 hours was mostly spent on tracking between print locations and other things (calibration, warming up, etc)?
Thanks again.
Napsal : 16/05/2018 4:08 pm
Kai
 Kai
(@kai-2)
Isn´t it the printer uptime right in the middle?
And the one beneath the total print time.
nec aspera terrent
Napsal : 16/05/2018 4:15 pm
TitanPrinter
(@titanprinter)
Now that you say it, I started this print almost 16 hours ago, so that must be it!
So, if you printed something that took 5 hours to print but it took you another 2 hours to get to the printer to remove it, the top would say 7 hours (7 hours since you started the print) while the scrolling would show 5 hours (the time it took to actually print).
I think that's the answer! Thanks for the help!
Napsal : 16/05/2018 4:22 pm
Justin DeWoody
(@justin-dewoody)
Correct.
Napsal : 16/05/2018 7:16 pm
