Knowing what color to change to with 3+ materials on single extruder
Preston
(@preston)
Hello everyone!
I recently starting the endeavor of printing with more than 1 material at a time on a single extruder machine, meaning I have to switch the filament manually. This is fine for 2 materials, but for 3+ materials it gets challenging to know which material to switch to.
I have written a python code where you can input your gcode filename and location on your computer and what colors you assigned each extruder to. You can then run the python code and it will parse your gcode to tell you what color to change to.
I couldn't find anything like this in my search, so I hope this helps somebody.
Code here
Napsal : 14/12/2020 7:09 am
RE: Knowing what color to change to with 3+ materials on single extruder
This post was in the
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/knowing-what-color-to-change-to-with-3-materials-on-single-extruder/#post-324199
forum,
I am not a Python person...
the Idea seems sound, but I am wary about the implementation!
see the image below
For a script that runs on My computer to edit My Gcode, there seem to be a huge number if Internet references, which makes me uncomfortable
Does anyone run python, and can they please have a look at this script.
Napsal : 14/12/2020 2:36 pm
misan
(@misan)
Member Moderator
@joantabb
Hi Joan,
I have reviewed this code https://github.com/PrestonHolt3/Gcode-Multimaterial-Parsing/blob/main/WhatColorToPut.py and I see no harm in it nor any URL.
Cheers,
misan
Napsal : 14/12/2020 3:05 pm
@misan
Cheers Misan,
Napsal : 14/12/2020 10:35 pm
