is there a reason the X and Y idlers aren't toothed?
toaf
 toaf
(@toaf)
would that add allot to precision? or think it would be overkill?
Publié : 29/07/2018 2:32 am
Bill
 Bill
(@bill-3)
Re: is there a reason the X and Y idlers aren't toothed?
I replaced my x idler with a toothed pulley. I really did not see a difference. Seems like it would be better, but it seems anecdotal at best.
Publié : 29/07/2018 3:33 am
toaf
 toaf
(@toaf)
nice to know...still tempted to do it.
Publié : 29/07/2018 3:44 am
RufusClupea
(@rufusclupea)
Good question, since the toothed idlers are less expensive than the smooth ones (at least on Amazon today). Perhaps not when OEM purchasing in bulk(?)
https://www.amazon.com/BIQU-20Teeth-Aluminum-Timing-Printer/dp/B01H3DSGAC/ref=br_lf_m_de9q8ergtqgrkeb_ttl?_encoding=UTF8&s=industrial
https://www.amazon.com/BIQU-Aluminum-Toothless-Timing-Printer/dp/B01H3FNZ4M/ref=br_lf_m_de9q8ergtqgrkeb_ttl?_encoding=UTF8&s=industrial
That's "MISTER Old Fart" to you!
Publié : 29/07/2018 7:20 am
thrawn86
(@thrawn86)
in my head it seems that it would give more consistent tension since the belt teeth are contacting fully with the idler teeth instead of just smashing the belt teeth down onto a smooth surface.
I don't think there are any downsides but it may not make a noticeable difference either way.
Publié : 29/07/2018 8:14 am
toaf
 toaf
(@toaf)
I just feel like I should eliminate anything that might give any play.
Publié : 29/07/2018 8:32 am
Nikolai
(@nikolai)
You're adding more friction with the toothed idler. If it doesn't fit perfectly, you're eating the belt faster.
But I think the mechanical difference is so minor in that case that other factors like easier quality control and availability made the run.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Publié : 31/07/2018 12:06 am
