Is Live Adjust Z saved?
buckeyestargazer
(@buckeyestargazer)
I'm wondering if the live adjust Z setting is saved for future prints, or does it revert back to the Z calibration I set earlier?
Best Answer by rmm200:
More than saved. It is recorded with each different print sheet you have. Smooth has it's own Z as well as Textured.
That value is swapped in when you tell the firmware what sheet you are using.
Opublikowany : 05/03/2020 6:25 pm
kpreid
(@kpreid)
RE: Is Live Adjust Z saved?
It is always saved.
Opublikowany : 05/03/2020 6:29 pm
1 ludzie polubili
rmm200
(@rmm200)
1 ludzie polubili
Just a slight addition, it is only saved as long as you have run through the initial calibration and z adjust at least once.  After that the live Z value is then saved.
Opublikowany : 05/03/2020 9:50 pm
1 ludzie polubili
buckeyestargazer
(@buckeyestargazer)
Thanks all.  I initially ran the calibration wizard so it should be all good.
Opublikowany : 05/03/2020 11:09 pm
