Internal structures affecting external perimeter of print, any ideas why?
Rick Lohr
(@rick-lohr)
Best Answer by Rick Lohr:
Well, I found the answer and it turns out to be really easy.  There is a switch that tells the slicer to do the outer perimeter first.  I turned that on, and the outer skin front printed with no hint of inner structures on it.  The back wall still had a hint but it turned out that wall was only three rows thick, so I widened it a bit and all is good.  My rule of thumb will be to keep inner structures at least 2 mm from outer walls.  I did change from 2 to 3 perimeters and I'm going to always use at least that too.
Napsal : 22/02/2024 7:06 pm
Robin
(@robin)
RE: Internal structures affecting external perimeter of print, any ideas why?
Because things are complicated, physics and stuff... There are quite a few rabbit holes to go down, and some don't go anywhere at all (like https://help.prusa3d.com/article/the-benchy-hull-line_124745 ).
Generally it is really really difficult to find and mitigate the cause of all those artefacts and distortions appearing on 3d prints. Increasing the number of perimeters and decreasing the print speed in general and/or the speed for the perimeters often helps.
Napsal : 23/02/2024 10:53 am
1 lidem se líbí
Zappes
(@zappes)
Just to give an extremely oversimplified, yet easily understandable explanation: The plastic shrinks, and it depends on the external structures just how much it can shrink. Think of the external perimeter as a vacuum bag - when you extract the air, the contours of the stuff in the bag will be visible.
My models on Printables
Napsal : 23/02/2024 11:23 am
Rick Lohr
(@rick-lohr)
Thanks, that gives me something to work with.
Posted by: @robin
Napsal : 23/02/2024 2:00 pm
Rick Lohr
(@rick-lohr)
I must be dense because I don't follow that at all, lol.
Posted by: @zappes
Napsal : 23/02/2024 2:01 pm
Zappes
(@zappes)
Posted by: @rick-lohr
According to my wife, failing to follow my ramblings is not an indication of density. 😀
What I meant to say: When the plastic cools down, it shrinks a bit. That's just basic physics. Now, when a piece of plastic that has a massive inner structure behind it shrinks, it can't go farther than that inner structure. In places where nothing is behind the plastic, though, the plastic will shrink a little more. It's like pulling a really tight skin over some structured object - you will be able to see the structure below.
Napsal : 23/02/2024 4:07 pm
Rick Lohr
(@rick-lohr)
Thanks for the clarification.  Now I know why I didn't understand.  My artifacts are actually indentations, not raised areas.
Napsal : 23/02/2024 6:00 pm
Rick Lohr
(@rick-lohr)
Napsal : 25/02/2024 5:01 pm
Rick Lohr
(@rick-lohr)
Napsal : 25/02/2024 5:06 pm
Rick Lohr
(@rick-lohr)
I looked at a print I did of this same object a year ago, and it was clean.  What could have changed that would do this?
Napsal : 29/02/2024 2:41 pm
