Instructions for Prusa Mk3S+ Upgrade
SeattleDavid
(@seattledavid)
I received the Prusa Mk3S+ upgrade box.
The QR code on the box does not go to a valid link. The QR code on the included sheet is also invalid.
Is there a link to the instructions to installing the kit, and a link to the files that need to be printed?
Postato : 21/01/2021 11:43 pm
Utenti
RE: Instructions for Prusa Mk3S+ Upgrade
https://help.prusa3d.com/en/tag/mk3s-2/
Postato : 22/01/2021 12:00 am
prusanewuser
(@prusanewuser)
Am I correct that those who bought the MK3/S to MK3/S+ Upgrade Kit need to print out some parts themselves?
Postato : 22/01/2021 12:12 am
Henry Casson
(@henry-casson)
Yes, they are on the site. I had difficulty with the Gcode, and I am now trying by doing each STL separately, using the settings recommended. You can buy them ready made from Prusa.
Retired doc, should have been an engineer.
Postato : 22/01/2021 3:26 am
Area51
(@area51)
Utenti
Yes parts need to be printed. There should be a roll of filament in the upgrade kit for the parts.
This product includes:
  • SuperPINDA
  • Bearing Clips for Y-axis bearings
  • IR filament sensor + cable
  • Hotend PTFE Tube
  • Fan shroud printed of ASA
  • PETG Filament to print the plastic parts
Postato : 22/01/2021 3:29 am
3DWillem
(@3dwillem)
Is it correct there is no difference anymore between the 'normal' MK3S+ lever and the one for the MMU2s ?
Postato : 22/01/2021 6:49 am
Utenti
If it is one of the parts in the ZIP, I would print it.
Postato : 22/01/2021 12:27 pm
Jadry
(@jadry)
I did the upgrade with the instructions but as I saw there is no guide to install optional X-Axis upgrade. I printed all the parts and screws are in the box but no instructions at all. I know I can use the assembly guide but it is a little bit more complicated with the extruder in place
Postato : 26/01/2021 9:40 pm
