Instructions for Prusa Mk3S+ Upgrade
I received the Prusa Mk3S+ upgrade box.
The QR code on the box does not go to a valid link. The QR code on the included sheet is also invalid.
Is there a link to the instructions to installing the kit, and a link to the files that need to be printed?
RE: Instructions for Prusa Mk3S+ Upgrade
https://help.prusa3d.com/en/tag/mk3s-2/
Am I correct that those who bought the MK3/S to MK3/S+ Upgrade Kit need to print out some parts themselves?
Yes, they are on the site. I had difficulty with the Gcode, and I am now trying by doing each STL separately, using the settings recommended. You can buy them ready made from Prusa.
Retired doc, should have been an engineer.
Yes parts need to be printed. There should be a roll of filament in the upgrade kit for the parts.
This product includes:
- SuperPINDA
- Bearing Clips for Y-axis bearings
- IR filament sensor + cable
- Hotend PTFE Tube
- Fan shroud printed of ASA
- PETG Filament to print the plastic parts
Is it correct there is no difference anymore between the 'normal' MK3S+ lever and the one for the MMU2s ?
If it is one of the parts in the ZIP, I would print it.
I did the upgrade with the instructions but as I saw there is no guide to install optional X-Axis upgrade. I printed all the parts and screws are in the box but no instructions at all. I know I can use the assembly guide but it is a little bit more complicated with the extruder in place
