I have a problem
janos_herc
(@janos_herc)
I have a problem
How is this possible? The printer was operating normally the entire time. I put one PLA print, after a few hours I come back and see this:
Is there any help for my printer?
This topic was modified 6 years temu by janos_herc
Opublikowany : 25/05/2020 8:48 am
RE: I have a problem
Good Morning,
there is Hope for your printer...
the Heater wire has broken on your extruder.
currently Prusa don't list available spare parts for the heater, however 'e3D online' do list spares
https://e3d-online.com/prusa-mk3-hotend-spares
If England is not a good location for you, there are resellers in other locations
https://e3d-online.com/resellers
for the Mk3 and Mk3S Printer, you are looking for a 40watt 24volt heater.
If I was ordering spar parts at this time, I would order two heaters and a Hot end thermistor.
the thermistor wires are very delicate, and may get damaged while making the repairs to the heater...
If you don't need the thermistor this time, you should end up with a spare heater and thermistor, for the future, and if you do damage the thermistor, you have one to hand, to save further delay.
If all  goes well, you will have a spare heater and thermistor, on hand in case you get a Blob of Doom, and damage them trying to remove the blob...
Opublikowany : 25/05/2020 9:47 am
1 ludzie polubili
Andrew
(@andrew-5)
Looking at the pictures there is a little bit of fraying on the sleeve. That suggests that it has been rubbing on the heated bed connector. Not enough to wear through but enough to cause the wire inside to move up and down. Done often enough it will snap the wire. I saw this when calibrating and have tried several times to move the sleeves up and away from the printed strain relief block. You could try rotating the heater in the heatblock slightly to make the cable behave better.
Andrew
Opublikowany : 25/05/2020 9:55 am
1 ludzie polubili
Knowlegdebase articles
https://help.prusa3d.com/en/guide/how-to-change-a-heatbreak-heatsink-heaterblock-mk3s-mk2-5s-mmu2s_16104
https://help.prusa3d.com/en/article/hotend-disassembly-heatbreak-stuck-in-the-heatsink_112677
https://help.prusa3d.com/en/guide/how-to-trim-ptfe-tube-original-prusa-printers_22424
Opublikowany : 25/05/2020 9:56 am
1 ludzie polubili
janos_herc
(@janos_herc)
Thank you very much! 🙂
Opublikowany : 25/05/2020 12:25 pm
