How to slow down jump speed for quieter print
SaH
 SaH
(@sah)
Changing the speed setting in tune reduces the movement speed and drastically reduces the noise of the motors/belt, however the transition speed between the different print areas is several times faster and makes a lot of noise. Is it possible to have the transition movement be the same as the print speed?
Napsal : 29/05/2020 8:40 pm
jsw
 jsw
(@jsw)
RE: How to slow down jump speed for quieter print
Wouldn't this be the 'Speed for non-print moves' in the Prusaslicer print settings?
I see that mine is (default I assume) 180 so you could easily cut that in half or more.
Napsal : 29/05/2020 8:48 pm
1 lidem se líbí
SaH
 SaH
(@sah)
@jsw
Thank you for quick response, but is it possible to change this during print?
Napsal : 01/06/2020 5:57 pm
not that I am aware of!
Napsal : 03/06/2020 12:17 am
