How to clean a MK3 hotend
GeneMpls
(@genempls)
I get a lot of old color 'wads' breaking loose in the midst of the next [color] print. Do the cleaning filaments help? Thanks Gene
Attachment removed
Respondido : 16/05/2019 1:57 pm
Vojtěch
(@vojtech)
RE: How to clean a MK3 hotend
Yes, a cleaning filament will help with this. A cold-pull using a cleaning filament even better.
Respondido : 16/05/2019 3:12 pm
GeneMpls
(@genempls)
I didn't think a cold pull was possible with our configuration? Do you pull out the short piece of boden tube? Thanks Gene
Respondido : 16/05/2019 6:45 pm
Posted by: gene.u
You can pull up through the extruder. Open the extruder door to remove tension before you do the actual pull. You can pull up through the PTFE tube without issue.
I'm still running the Mk3 (pre-S) configuration, but my notes here should still be helpful.
Respondido : 16/05/2019 8:11 pm
Sembazuru
(@sembazuru)
I've successfully done cold pulls (with eSUN Cleaner Filament, non affiliate link and same product as in bobstro's notes webpage) with both the MK3 and MK3S extruders. Open the Bondtech idler door for both. No problem with hanging up on the lower PTFE tube on both, nor the top PTFE tube on the MK3.
See my (limited) designs on:
Respondido : 16/05/2019 8:46 pm
GeneMpls
(@genempls)
Thank you Gentlemen. I use the printer [I have the MK3s parts on the way] everyday and make a lot of parts for my CNC router and CO2 laser cutter. It [and Fusion 360]  has opened a new world to me in my dotage [I am 73].
Respondido : 17/05/2019 1:16 pm
scott.b47
(@scott-b47)
Also, make sure the exterior of your hotend is clean. I just finished a 3.5 hr white PC print where I happened to have left some black PETG stuck to the nozzle. I actually noticed it an hour in, but figured it's only a little bit of cosmetic imperfection, it can't really hurt that much. A little bit of plastic stuck to the exterior of a nozzle (or stuck to the outside of a sock) will decide to fall or drip off at the worst possible time.
Of course, upon completion I wasn't happy with it and I'm now reprinting it anyway.
Respondido : 18/05/2019 12:18 am
1 les gusta
JMcK
 JMcK
(@jmck)
What do you use to clean the outside?
When someone asks you if you're a god, you say, "YES!"
Respondido : 19/05/2019 2:24 am
Posted by: joe.m14
A soft brass wire brush works, but be careful around the heater cartridge & thermistor wires.
Respondido : 19/05/2019 3:32 am
Also, consider a silicone sock to avoid build-up of filament on the heater block.
Respondido : 19/05/2019 3:39 am
scott.b47
(@scott-b47)
Posted by: joe.m14
These days I'm using an E3D Nozzle X together with a non-pro sock (the kind that doesn't cover the nozzle). The Nozzle X is plated and has a nonstick coating and cleans up easily with a paper towel while hot. One of the benefits of this particular nozzle.
For a standard brass nozzle, or if you weren't running a sock and your heater block is covered with stubborn baked-on goo, the soft brass wire brush that bobstro recommends is the way to go. Having to do this one time on a non-socked heater block was enough to convince me never to run without a sock again. I really think they ought to include a 3-pack with the printer.
Respondido : 19/05/2019 4:43 pm
I've found a strip of cardboard works better for coated nozzles than paper towels. Less lint and tearing, and can just trim it off when it gets messy.
Respondido : 19/05/2019 6:36 pm
