How do I create a custom move on each layer using gcode or other method.
Jeffsy
(@jeffsy)
How can I code some custom moves at the end of each layer?
On each layer completion I would like an absolute move of Z=100mm, then X =200mm (for example) then return to the next layer.
Thanks for your help.
Veröffentlicht : 05/09/2022 5:01 pm
Printer Settings > Custom G-code > Before layer change G-code    and   After layer change G-code
Veröffentlicht : 05/09/2022 5:29 pm
Jeffsy
(@jeffsy)
RE: How do I create a custom move on each layer using gcode or other method.
Hi Diem,
Any chance of listing the the code using my example co ordinates?
thanks
Veröffentlicht : 05/09/2022 5:54 pm
do you seriously want to move to X200 Z100 after every layer,
Z travel is vertical, and SLOW...
the print will take ages
G1 X200 Z100   should do the job for you...
Veröffentlicht : 05/09/2022 6:49 pm
As you are posting in the MK3 forum then can we assume you are using a MK3 printer ?
If so then normal 'in print' moves will already be set to absolute positioning.  If you dont know enough to work it out yourself then you really shouldnt be touching the custom gcode areas as you can damage things by improperly adding gcode.
However its your printer so you can do what you want.
After layer
G1 Z100 ; moves extruder to height 100
G1 X200 ; moves extruder to x=200
Thats it.  Its all thats needed to go to that same position on every layer.  It will go back to the next layer position as that will be the next gcode and its already in absolute mode.  I would presume its for some kind of camera setup.  Hope you don't forget to leave it in though and ever print something above 100mm high.
Veröffentlicht : 05/09/2022 6:53 pm
