Help please
I don't know it this is in the right place but I am having a problem with my printing that just started today. It was perfect yesterday. I didn't change anything, I just turned on the printer and tried to print and this is what I got.
I would really appreciate any help.
Thanks.
Bob
Re: Help please
Not an expert, but I would try:
1) Check for a nozzle clog. A partial clog can cause this inconsistent extrusion
2) Clean the bed. Use dish soap and IPA. Then use acetone if that doesnt work.
3) Check your Live-Z calibration. It can be changed by random machine shifts at times even though you think nothing changed.
4) Finally, did you leave your filament out in high humidity? Depending on the filament type, you may need to dry it.
Re: Help please
Thanks. The only thing not checked and ok is the nozzle clog. I will do that today.
Re: Help please
Nozzle clog was the problem. Working perfectly now.
Thanks for your help. Glad you are here. 🙂
Bob
