Functions, On or Off in Slic3r
Dewey79
(@dewey79)
Since I received my MK3 early this year we were told to leave several functions off due to them causing problems. Some of these functions included "linear advance", the "filament sensor" and others.
Now that firmware and Slic3r has been updated what should be turned on and what should be turned off? Is there a page under support that lists that current recommendations?
Veröffentlicht : 11/09/2018 10:30 pm
thrawn86
(@thrawn86)
Re: Functions, On or Off in Slic3r
linear advance will be re-enabled if you're using current firmware and slic3r profiles. Filament sensor still is dependent on your material so no change there. what else is there?
the firmware changelogs would be good if you want more detail but at the moment the only thing you should need to touch is the filament sensor.
Veröffentlicht : 12/09/2018 11:04 pm
keithywhites
(@keithywhites)
theres a new firmware release today: https://www.prusa3d.com/drivers/#_ga=2.69975636.579346879.1514176604-595147110.1513113858
if you download the current drivers and apps there also, everything is all set up. linear advance is setup already in the new version of slic3r p.e.
Veröffentlicht : 12/09/2018 11:18 pm
