Full model not highlighted when selected
happyday.mjohnson
(@happyday-mjohnson)
I got a model from thingiverse.
it is one object, however the cap is not highlighted when seleccted.  Meaning things like paint on supports won't work correctly.  Other models don't show models that have unhighlighted parts.  Why is this happening?
Thank you.
Postato : 28/07/2022 3:56 pm
RE: Full model not highlighted when selected
The model is almost certainly broken. The dark green areas are an immediate indication of that, does it have yellow triangle next to it in the list ?  Hover over that and it will tell you how many errors it has. If you are on windows you can try right clicking and fix through netfabb option. If not then you will have to find some other way to fix it.
Postato : 28/07/2022 4:32 pm
happyday.mjohnson
Thank you very much.  Your reply taught me to look at the errors first.  Many Thingiverse files do have errors.  However, almost always they print find.  In this case, that was not the case.  Happily, I was on Windows and fixing worked.
It is indeed a Happy Day.  Thank you.
Postato : 28/07/2022 5:29 pm
Swiss_Cheese
(@swiss_cheese)
BTW, The errors your seeing in the darker area are (Flipped Normals), that's how Slicer shows them.
Good Luck
Swiss_Cheese
Questo post è stato modificato 3 years fa 2 tempo da Swiss_Cheese
The Filament Whisperer
Postato : 28/07/2022 11:24 pm
happyday.mjohnson
Thank you @swiss_cheese .  That is good to know.  And yes, sometimes luck is involved. :-).
Postato : 29/07/2022 11:55 am
