fsensor_stop_and_save_print
The printer hasn't had any modifications made to it for a long time. However today, it has started giving this error, multiple times.
I'm using Octoprint to drive the printer, and looking in the console I'm getting :
Send: N93179 G1 X106.191 Y58.832 F10800*73 Recv: ok Send: N93180 M204 S800*109 Recv: ok Send: N93181 G1 F2100*79 Recv: ok Send: N93182 G1 X106.184 Y58.835 E.00026*110 Recv: ok Send: N93183 G1 X106.125 Y58.979 E.00527*105 Recv: ok Send: N93184 G1 F2099.996*83 Recv: ok Send: N93185 G1 X106.125 Y82.502 E.79622*96 Recv: ok Send: N93186 G1 X105.45 Y82.502 E.02285*82 Recv: ok Send: N93187 G1 F2100*73 Recv: ok Send: N93188 G1 X97.25 Y82.502 E.27756*108 Recv: ok Send: N93189 G1 F2099.996*94 Recv: fsensor_stop_and_save_print Recv: fsensor_update - M600 Recv: echo:Enqueing to the front: "PRUSA fsensor_recover" Recv: echo:Enqueing to the front: "M600" Recv: echo:busy: processing Recv: echo:busy: paused for user Recv: echo:busy: paused for user
I remove the filament, trim the end (to remove the blob / but an angle on it), replace it, and away it goes again. It might go 20 seconds, it might go 10 minutes, then it happens again.
Looking at the gcode in the Prusa Gcode viewer, there is nothing there telling it to change filament, which leads me to think that it is a printer rather than gcode problem.
Any suggestions on where to look next ?
TIA
Adrian
Respondido : 03/03/2026 2:44 pm
