First time 0.6mm/0.8mm Nozzle user - what do I need to change?
Alpha
(@alpha)
Hi all,
Quick sense check - wanting to start using a 0.6mm nozzle for things.
What do I need to change for this?  Is it just screw the nozzle in, adjust the nozzle diameter setting in Prusaslicer and away I go?
Or is there other settings I need to fiddle with?
Opublikowany : 20/10/2019 7:02 pm
RE: First time 0.6mm/0.8mm Nozzle user - what do I need to change?
Posted by: @katie-o
[...] Quick sense check - wanting to start using a 0.6mm nozzle for things.
The basics are nozzle size, extrusion width and layer height. Be sure to re-calibrate your Live-Z after a nozzle swap. I've got more detailed notes on creating PrusaSlicer profiles here. Pay attention to the notes in the green box if profiles start disappearing.
Opublikowany : 20/10/2019 7:23 pm
Also make sure you follow the e3d guide on changing a nozzle to get it sealed to the heatbreak properly.  If you dont you will have leaky plastic and uneven extrusion as best case.
Opublikowany : 21/10/2019 7:14 am
