Firmware 3.6.0-FINAL for Original Prusa i3 MK3S & MK3
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
WARNING: Note that MK3S, MK3, MK2.5 and MK2.5 are different printers! Each has its own firmware file!!!
Hi guys,
this is a final version of the firmware recommended to all users. Compared to the 3.6.0-RC1 smarter load/unload/eject" has been improved.
What is new?
-> Initial version for MK3S and MK2.5S printers with MMU2 unit
-> Smarter load to nozzle/unload/eject function for multi material printers and single material version improved
-> Stop print during filament change fixed
This the first firmware to support MK3S/MK2.5S printer with MMU2 unit. This combination of hardware is officially called MK3S MMU2S or MK2.5S MMU2S.
This feature has been recently added to firmware in 3.5.2-RC1 version, but this initial version has been working only for single material printers (without MMU2 connected). In this firmware version, it has been extended to provide similar function also for multi material printers. We also decided to change function slightly to make it more useful for most users. When a user chooses to load filament (for example) with the cold nozzle for example, preheat menu appears and both nozzle and heatbed are preheated (to save some time later when starting a print) and printer waits for the nozzle to preheat close to the target temperature (5% below target). When preheating is finished, printer beeps and the user can start loading filament. Target temperature remains the same after the load is finished as we assume that most load/unload scenarios precede starting new print.
When stopping print during the T-code execution nozzle could crash into wiping tower. This has been fixed.
Supported printers:
Original Prusa i3 MK3S MMU2S
Original Prusa i3 MK3 MMU2
Original Prusa i3 MK2.5S MMU2S
Original Prusa i3 MK2.5 MMU2
Download link:
https://www.prusa3d.com/drivers/
Firmware flashing guide:
https://manual.prusa3d.com/Guide/Upgrading+the+firmware+v1.5/66
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Respondido : 04/03/2019 1:53 pm
Soliddev
(@soliddev)
Re: Firmware 3.6.0-FINAL for Original Prusa i3 MK3S & MK3
Hi I have an i3 MK2.5 + MMU2 that I have been having problems with. Having fixed some mechanical problems with the MMU2 (reprinted parts on another lesser machine) I uploaded the latest firmware on the Prusa website and flashed both the MMU2 and the Printer. The firmware seesm to introduce loads of issues -
Random Minimum Bed Temp warnings when it's at 30 degrees!
Inability to run the First Layer Calibration (just sits there after the initial wipe but continues to extrude)
Grinding Extruder gears (sometimes going in the wrong direction!
I checked that I had downloaded the correct version for my machine (which I had) so I assumed it was a corrupted download or flash, so I tried again twice - the second time doing a fresh download from the website. This had just the same end result. NB I have done 'factory resets' as well before and after flashing - all just the same.
So today I reverted back to the previous firmware (downloaded fresh) and the machine is now able to run the first layer calibration and has successfully completed a test print.
I am waiting for delivery of the MK2.5S upgrade but have lots of work I need to get completed for clients so this is all very frustrating.
Any chance you could look into it and see if there is a problem at your end tailoring for the MK2.5 + MMU2?
Thanks,
Adrian
Respondido : 07/03/2019 4:22 pm
Dave
 Dave
(@dave)
I just updated to 3.6.0 about an hour ago. Now whenever I send a job to the printer, the extruder scoots over to the corner and asks me to unload/load the filament. I do and it does, then heads over to the front left corner as if to start the print. It then heads over to do a filament change again. And again. And again.
I've rebooted via soft reset, I've powered off the printer for 5 minutes, I've restarted Sli3er...I'm not sure what else to do here.
I have an i3 MK3 3D printer. Did I install the wrong firmware maybe?
Here's the log from the 2nd filament reinstall:
echo:busy: paused for user
echo:busy: processing
echo:enqueing "M220 S100"
fsensor_restore_print_and_continue
T:216.7 E:0 W:?
T:217.0 E:0 W:?
T:216.4 E:0 W:?
T:216.3 E:0 W:?
T:216.0 E:0 W:?
T:216.3 E:0 W:2
T:216.0 E:0 W:0
Error:Line Number is not Last Line Number+1, Last Line: 45
Error:No Line Number with checksum, Last Line: 45
Error:Line Number is not Last Line Number+1, Last Line: 46
Error:No Line Number with checksum, Last Line: 46
fsensor_stop_and_save_print
fsensor_update - M600
echo:Enqueing to the front: "FSENSOR_RECOVER"
echo:Enqueing to the front: "M600"
Full RX Buffer
start
echo: 3.6.0-2069
echo: Last Updated: Mar 1 2019 13:59:42 | Author: (none, default config)
Compiled: Mar 1 2019
echo: Free Memory: 2083 PlannerBufferBytes: 1392
echo:Stored settings retrieved
adc_init
CrashDetect ENABLED!
FSensor ENABLED
echo:SD card ok
MMU not responding - DISABLED
Print aborted at 11:58:03
Respondido : 08/03/2019 6:12 pm
L3D-Printing
(@l3d-printing)
I was very happy to see:
But this is not the case. Several prints with this firmware still have the crash into the wiping tower.
Actualy, the problem is a bit different. When the filament is unloading, the heat from the nozzle heat's up the wiping tower
which deforms. The next time the nozzle passes a ridge and after a few layers the wiping tower is kicked off the build platform.
I hope this helps. Maybe the nozzle needs to move to an aera between printing object and wiping tower?
Respondido : 09/03/2019 6:49 pm
SoBaldrickEsq
(@sobaldrickesq)
I have a Mk2.5, and am suffering from the same issues of randon min bed temp alarms when bed is heating up. going to revert back to 3.5.2
Respondido : 10/03/2019 10:13 am
SoBaldrickEsq
(@sobaldrickesq)
i checked and mine is at 30 degress as well, have downgraded to 3.5.2, and will monitor and update.
Respondido : 11/03/2019 11:36 am
MrPuffyNZ
(@mrpuffynz)
Yes i tried the 3.6.0 on a MK3 and everytime i tried to print it would want to unload the filament and also the autoload no longer worked so i have gone back to 3.5.1.
Respondido : 14/03/2019 10:12 pm
marchyman
(@marchyman)
Yes, but WHICH 3.6.0 did you try, the one for the MK3 or the one for the MK3S? Load the wrong one and your filament sensor won't work.
FWIW the MK3S version of 3.6.0 is working fine on my MK3S.
Respondido : 15/03/2019 2:18 am
fnice
(@fnice)
for the MK3, is it possible to edit the firmware to keep the Live adjust Z through out the print then it going away after so many layers? where would this option be in the firmware?
Respondido : 15/03/2019 10:15 pm
pacaj2am
(@pacaj2am)
I see a temperature drop issue with this firmware. Printer is in enclosure LACK and plexi. No sudden temperature changes in the room.
Respondido : 16/03/2019 2:33 am
Dash
 Dash
(@dash)
I am having a different type of problem. Now when my printer sees the second t-code it just stalls. The temps are all good and it will run all the way through the purge line but then it stalls at that spot.
I would like to be able to print without having to hand edit my gcode file everytime.
thanks in advance
; generated by Slic3r Prusa Edition 1.42.0-alpha5+ on 2019-03-18 at 19:11:37
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.42mm
M73 P0 R497
M73 Q0 S501
M201 X1000 Y1000 Z1000 E8000 ; sets maximum accelerations, mm/sec^2
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm/sec
M204 P1250 R1250 T1250 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E1.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
M107
M115 U3.5.1 ; tell printer latest fw version
M83 ; extruder relative mode
M104 S215 ; set extruder temp
M140 S60 ; set bed temp
M190 S60 ; wait for bed temp
M109 S215 ; wait for extruder temp
G80 ; mesh bed leveling
G21 ; set units to millimeters
; Send the filament type to the MMU2.0 unit.
; E stands for extruder number, F stands for filament type (0: default; 1:flex; 2: PVA)
M403 E0 F0
M403 E1 F0
M403 E2 F0
M403 E3 F0
M403 E4 F0
;go outside print area
G1 Y-3.0 F1000.0
G1 Z0.4 F1000.0
; select extruder
T0
; initial load
G1 X55.0 E32.0 F1073.0
M73 Q0 S500
M73 P0 R497
G1 X5.0 E32.0 F1800.0
G1 X55.0 E8.0 F2000.0
G1 Z0.3 F1000.0
G92 E0.0
G1 X240.0 E25.0 F2200.0
G1 Y-2.0 F1000.0
G1 X55.0 E25 F1400.0
G1 Z0.20 F1000.0
G1 X5.0 E4.0 F1000.0
G92 E0.0
M221 S95
M83 ; use relative distances for extrusion
G92 E0.0
T0 ***this is where it stalls always, if I remove it it works fine**************
M900 K30; Filament gcode
G1 Z0.200 F10800.000
;BEFORE_LAYER_CHANGE
G92 E0.0
;0.2
Respondido : 19/03/2019 12:51 am
doa
 doa
(@doa)
if you don't have multi-material, just comment it out in Slic3r setting. not sure why it's there
Respondido : 24/03/2019 3:04 pm
Daniel Novet
(@daniel-novet)
Downloaded, flashed, started the first print.
While waiting for the printer to heat up getting shocked while reading the forum... 😮
Was the update a mistake? Do I need to roll-back onto a previous version? 😕
So far I LOVE the refined calibration of 7x7 and increased number of probing-points! I can clearly see the z-axis moving in different speeds while it's drawing a line across the whole bed (it's a large flat print...). 😎
Quite a satisfactory thing, to watch it doing it, mesmerizing...
Also notable is the difference in silent-mode of the MMU...
Makes the printer a whole level less noisy!
Because I had to move homes, I was only able to update the printer after almost three months, but boy, is this an improvement...!
For those errors reported before my post - none of these happened here...?
Jakub,
please extend my greatings to the team, please keep the good work up! 🙂
Respondido : 02/04/2019 12:04 pm
doa
 doa
(@doa)
What do you mean? Reports in other topics? In this particular topics there's not many things reported, where is the bug report list?
Respondido : 02/04/2019 12:29 pm
