Filament tangled on spool
Tango
(@tango)
I had this issue a few times while doing a 3 hour print last night:
I had to deal with that several times. When I heard the noise that indicated it was tightening up, I went over and adjusted it. Also noting this is a reel of filament that generally works okay on my Prusa, but was bought for my Ender 3 Pro (that just won't behave anyway).
Is this a "hazard" of 3D printing that normally needs to be watched out for? Or is it likely an ID-10-T error (i.e. user error) because I may have let it happen when the filament started to unspool and I was sloppy when I put it back on? And if that's the case, I've seen clips to hold the filament on the spool, but they all look like they stay in place. Is there a clip I can use on a spool that will slide along the edge of the spool as it turns and filament spools off it?
Opublikowany : 02/07/2022 7:00 pm
oriddlero
(@oriddlero)
I print a few spools a a week, it happenes from time to time.  This helps - https://www.printables.com/model/1299-filament-guide
If my post helps you please consider downloading & making one of my most popular Prusa-Printables 3D models below:1. Ultimate Printer Knob Upgrade - The Best Knob of Both Worlds 2. Prusa MK3S Right…
Opublikowany : 02/07/2022 7:50 pm
1 ludzie polubili
jsw
 jsw
(@jsw)
RE: Filament tangled on spool
I've had a few tangled spools, and I must admit they were pilot error.
Some people swear that they've received tangled spools from the suppliers, but if you think about how they are wound, that's close to impossible.  Somebody in the factory would need to be  very negligent to let that happen.
Opublikowany : 02/07/2022 8:02 pm
2 ludzie polubili
Never let go of the end of the filament! Or that's what you're  going to get.
Opublikowany : 02/07/2022 9:47 pm
1 ludzie polubili
oriddlero
(@oriddlero)
Or if you do let go if you have a filament guide like I posted above and a dust filter, something like this, the spool won't unravel on you and get crossovers which is what leads to this problem.
Opublikowany : 02/07/2022 10:07 pm
Tango
(@tango)
Do I need to put something like cotton in the dust filter or does it just grip the filament tight enough to scrap dust off? And where do I mount it?
I'll be printing up the filament guide soon.
(I'm also realizing one of the 2-3 big issues about why my Ender has never printed well is poor design - the way the filament goes into the extruder on that, it has a rather sharp right angle. I was noticing that just now, before I got on the computer and saw this. So I'll need a guide there, too.)
Opublikowany : 03/07/2022 2:31 am
Swiss_Cheese
(@swiss_cheese)
@tango
No you don't need any of the extra stuff people mention relative to your machine, some folks just like to mod their machines, that's the fun in for them . you don't need any of that to print and print well.
The one acceptation might be a quality filament dryer.
It's a personal preference, you will meet people that swear, it's the way to go. I would focus on learning the software, and the specifics of your machine, as well as the basics of printing with your filament choices.
Regards
Swiss_Cheese
The Filament Whisperer
Opublikowany : 03/07/2022 3:44 am
1 ludzie polubili
JustMe3D
(@justme3d)
Adding a filament guide is imho not a mod but a means of fixing the fact that there are hundreds of different spool qualities out there. Look at the technical issue: printing large items covering much of the build plate may result in a transit of the extruder from, say, front left to rear right when changing to the next layer. This results in a very long piece of filament having been pulled from the spool to print left front to being pushed back when the extruder moves rear right. The filament then, particularly on full spools, may jump off the spool or may after some time, sneak itself under the next, yet not unwound but already loose loop of filament on the spool. When the extruder then suddenly travels a longer distance again, the loop is tightened again,  catching its "predecessor", re-wound filament underneath. Do this a couple of times and you have a perfect knot of doom. Filament wanders on the spool left and right in these circumstances.
The guide results in the filament being pushed back not on the spool but into a curve between extruder and guide, usually avoiding the filament to be pushed fully back to the spool. The dust filters I have never made use of, a simple guide attached to the i3 upper frame does it for me. Those who print smaller items on a limited part of the plate might never encounter the.issue.
Cheers
Chris
Opublikowany : 03/07/2022 6:19 am
1 ludzie polubili
oriddlero
(@oriddlero)
Posted by: @justme3d
 100% this.  This guy gets it.  Even with a perfect spool, with large prints on a full spool, filament can jump off the spool sides and cause a tangle.  A centered filament guide corrects this.  Ask me how I know.  Its 's a no-brainer imo.
Regarding your question on the dust filters.. yes you need to fill them with a piece of a cut-up sponge, the cheap yellow sponges work great one sponge will probably last you a lifetime you just cut little pieces of it off to fit inside of the dust filter. You'll be surprised how much gets pulled off the filament each spool. It also has the added benefit of holding the filament for, kind of like a clamp so it doesn't back out past the filament guide when you remove filament from the extruder to change colors or do maintenance/whatever.
This post was modified 4 years temu by oriddlero
Opublikowany : 03/07/2022 12:13 pm
