Filament doesn't stuck hotbed during first layer print
inoskyh
(@inoskyh)
Hi there,
I own a MK2S MM upgrade with tenth of hours of successful printing but since few days, the PLA filament don't want to stuck on the hotbed anymore.
This started after I got problem with filament loading: one was still engaged in multiplexer after aborting a print, and other extruders could not push their filament anymore. I had to disassemble teflon tubes and extract metal tube from the multiplexer. The filament was stranded in it, and I had to use some fire to melt the filament and extract it from the tube.
Everything re-assembled, I did several XYZ calibrations and found back an acceptable Z-adjust setting (well I believed actually) but till then, the filament never stuck on hotbed at the very beginning of the print, ending every time with a blob accumulating on the nozzle.
I iterated on the Z-adjust part, using "First Layer Calibration" menu, but either it's too low but it correctly stucks, either it's too high and it doesn't stuck. I found several time a correct setting, but the first print totally failed because the filament didn't stuck.
For information, I clean my hotbed before every print with IPA and a towel sheet, hotbed cold.
I can't fix the problem by myself this time, please help!
Postato : 12/05/2018 11:26 am
Re: Filament doesn't stuck hotbed during first layer print
good morning Nicholas,
sometimes PEI needs a bit more cleaning,
it is hard to see from your picture, whether there is good live Z layerheight...
as a first step, could you try cleaning again,
use soap and water carefully, first. then isopropyl alcohol
and try again
other alternatives include scrubbing the bed with a clean pan scourer
or wiping the bed with acetone
note nail varnish remover is not suitable, because it contails oil
Postato : 12/05/2018 11:42 am
inoskyh
(@inoskyh)
Hi Joan,
Yeah, that was it!!!
I cleaned as you described, I guess some oil remained from when I put some lubricant on axis.
Do you know at which frequency I have to clean my heatbed using water soap and sponge? And IPA?
Again, thank you a lot, I can come back to work printing tones of parts :p
Nicolas
Postato : 12/05/2018 3:04 pm
