Feature to resume a print
Chris Plumlee
(@chris-plumlee)
I do a lot of printing with ESD PLA, which is more brittle than standard PLA.  It occasionally snaps off during a print just before the head without detection, and the print head continues waving merrily about in the air until I stop the print.  Manually editing the gcode to pick up from where it was left off is very tricky.  Prusa should add a resume feature allowing one to rewind from the end of a file through the layers (not the X and Y travels; just the Z) to the desired starting point.
Publié : 17/03/2023 5:02 pm
If this is the semi-conductive filament with C nanotubes then it is VERY sensitive to humidity.  As it absorbs moisture the nanotubes don't swell with the filament and it micro-cracks.
This is another filament where drying and maintaining dryness is important.
Publié : 18/03/2023 1:30 am
