Fan shrouds melting too often
Page 3 / 3
RE: Fan shrouds melting too often
@hellbender-2
- https://www.prusa3d.de/downloads/others/MK3_MK3StoMK3S+_STL.zip
- SPINDA
- Bearing Clips Y-axis
- hotend PTFE
or
Prusa offers an upgrade kit: https://shop.prusa3d.com/en/original-prusa-i3-mk3s/1390-original-prusa-i3-mk3-to-mk3s-upgrade-kit.html
Posted : 10/02/2021 11:11 pm
All and all, the upgrade kit is not a bad priced upgrade.
Posted : 11/02/2021 2:10 am
pcweber
(@pcweber)
@cwbullet
Not at all, I just finished the upgrades and although the printer was working fine, it appears to be better.
  1. I did the extruder upgrade right after the files were available. Better cooling and the better fan shroud.
  2. Although not required I did the x-axis upgrade, belt tension adjustment easier.
  3. The best part is the y-axis upgrade, after adding the clips are the rod holders. My skew is now 0.03, well within tolerance.
Now, I'm in the process of completing the calibration routines, but it looks great!
Stay safe and healthy, Phil
Posted : 11/02/2021 10:46 am
@pcweber
Good to hear.  I might slowly upgrade mine.  I have one kit and another on the way.
Posted : 11/02/2021 11:30 am
@cwbullet
I think so too, if you add up the effort and the material.
Posted : 11/02/2021 1:39 pm
pcweber
(@pcweber)
@karl-herbert
There could've been a set of mitsumi bearings to replace the ones that have been rolling along for a year. I simply cleaned the bearings in a zip lock bag of IPA, then regressed them.
The machine is quieter so I suppose they needed regreasing.
Posted : 11/02/2021 2:10 pm
@cwbullet
I checked with Extrudr. Unfortunately, there is no distributor in the US at this time, but they would offer a 30% discount for shipping to the US.
original message:
Hallo Karl,
danke der Nachfrage und vielen Dank für die Empfehlungen.
Nein, im Moment liefern wir nur als OEM (white Label) nach USA.
Was natürlich möglich ist, eine Bestellung über www.extrudr.com.
Gerne können wir dir 30% Rabatt auf die Produkte anbieten. Der Versand in die USA kostet aber schnell mal einiges. 35-160€ für ein 30kg Paket.
Durch denn Rabatt wiegt es sich dann aber sehr gut auf. 🙂
Falls du Interesse hast, einfach per Mail melden.
Grüße
Mit freundlichen Grüßen,
extrudr
e: [email protected]
p: +43 660 88 10 615
w: extrudr.com
Posted : 11/02/2021 3:40 pm
Thanks.
Posted : 11/02/2021 3:49 pm
Martijn
(@martijn)
It's been awhile, thought I post an update.
I've been using the following Fan Shroud with success:
https://www.thingiverse.com/thing:4106196
Printed it in PETG and now also use a sock
Haven't had any issues since 🙂
Posted : 05/03/2021 10:10 pm
@martijn
I tried this shroud and it worked well for me too.
Posted : 12/04/2021 7:02 pm
jmichaels
(@jmichaels)
I know I'm a bit late to the discussion, but after reading this thread I thought I'd share the duct I've been using. I printed the first one with PETG and it held up great through 100+ hours of printing (PLA/PETG), has a little extra clearance from the heater block and a support arm so both sides are properly supported. The only downside I've found is that it's a bit bulky compared to stock which makes it a little harder to see the nozzle when close to the bed.
Printing a new one in Polymaker PC-Max now:
https://www.prusaprinters.org/prints/39679-prusa-mk3s-and-mk3s-fan-duct-with-pinda-support
Hope that helps someone, and kudos @kalleknall for the remix!
Posted : 17/04/2021 10:24 am
Frog
 Frog
(@frog)
I've been using Extrudr GreenTec Pro for my fan shrouds since more than a year and never had any temperature problems with it.
Posted : 23/04/2022 5:47 pm
Cadme1ster
(@cadme1ster)
I used Polymaker CoPA ( https://eu.polymaker.com/product/polymide-copa/) = PA6 / PA6.6 blend.
This stuff has the Vicat softening temperature ( https://en.wikipedia.org/wiki/Vicat_softening_point) at  180°C, I highly recommend this for the fan shroud.
For comparison: Vicat softening temperatures:
  • PLA 63°C
  • PETG 84°C
  • ABS 104°C
  • PC 130°C
This post was modified 4 years ago 2 times by Cadme1ster
Posted : 19/05/2022 8:02 am
Page 3 / 3
