[Risolto] extruder-idler door
Graham
(@graham-2)
extruder-idler door
 can anybody tell me if the extruder door which is very sloppy on the screw has any effect on quality?
have put new 3.9 fw in and seemed to loose quality about the same time.
been using petg and high speeds doing the covid parts, which the extruder started clicking, could not find it at the time thought it was the ptfe tube. which i changed.
this was all good until now doing some thin wall petg, the quality was way down to what it has been.
stringing and inconsistent blobs all over, with the same settings and same petg
printing a new door on the Ender 3
Thanks Graham
Postato : 24/05/2020 10:59 am
Graham
(@graham-2)
RE: extruder-idler door
Printed a new door on the Ender 3, looks like it has solved the problem, what is odd i have never had auto load working till now.
could the door have been faulty from when it was built? may be
The main thing is i found it and solved 2 problems at once, that cant be bad!
Postato : 24/05/2020 2:15 pm
Andrew
(@andrew-5)
My auto load didn't work until I found there was a fault with the IR sensor (nipped down just a bit too tight). Maybe having pullet it apart so many times your IR is now working.  Worth remembering next time if you ever have to pull it apart.
AD
Postato : 26/05/2020 12:39 pm
Graham
(@graham-2)
@andrewld
I think you are right,  mine has been to bits too many times.
Hoping to leave it alone for some time.
Postato : 26/05/2020 12:42 pm
