Error: Max Temp
co3Darts
(@co3darts)
Error: Max Temp
I came into my print room and my MK3s was sounding an alarm!
I was a couple minutes into a petg print and saw that the hotend temp read 597 degrees!  This isn't even possible is it?
Not sure what to troubleshoot.  I replaced the entire hotend/heat break with an E3d nozzle a month ago.  I'm guessing it's a bad thermistor but showing this temperature makes me wonder if it's a bad board or something now?
Love to hear some ideas!
Attachment removed
Opublikowany : 10/02/2021 5:21 pm
RE: Error: Max Temp
Posted by: @co3darts
Attachment removed
This could be the result of a short circuit thermistor.
what temperature does it show at rest?
unplugging the thermistor should give a mintemp error and show less than 15C probably 0C.
if the temperature shows high at rest, try wiggling the cable bundle behind the extruder, see if it changes
Opublikowany : 10/02/2021 5:26 pm
co3Darts
(@co3darts)
RE: Error: Max Temp
The physical heat the printer is able to reach is really approx 300 degrees celsius.  Is that true?  I have to leave right now but will inspect thermistor this afternoon.
Thank you Joan.
Opublikowany : 10/02/2021 5:28 pm
RE: Error: Max Temp
@co3darts
Hotend can reach about 295C on a standard mk3 series printer but I wold never try to work at that temperature because any fluctuation is likely to take you over the limit into Maxtemp!
Opublikowany : 10/02/2021 6:59 pm
