Drivers 2.1.5 with Slic3r PE 1.39.2
UPDATE: this version is replaced by Drivers 2.1.6, download them here: https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/drivers-2-1-6-with-slic3r-pe-1-39-2-t18925.html
Hi guys,
this is the newest release of drivers and software for MK2/S/MMU, MK2.5 and MK3. Included is the latest stable release of Slic3r Prusa Edition.
What is new:
Slic3r PE updated to 1.39.2
Latest version of Slic3r Prusa Edition brings new cooling slow down logic as a result, the print quality of smaller objects is improved. Learn more about the cooling logic here.
Run "Help - > Configuration Assistant" to apply the latest settings
Updated Windows installer
Our team created a brand new installer for Windows with a smarter installation procedure, latest material and printer profiles.
Pick your printer to install appropriate settings and models
Supported printers:
Original Prusa i3 MK3
Original Prusa i3 MK2/S/MK2.5
Original Prusa i3 MK2/S Multi Material
Supported platforms:
Microsoft Windows
macOS
Linux (see Appimage on Github)
Download link:
http://www.prusa3d.com/drivers
Looking forward to your feedback! Happy printing 😉
/ Knowledge Base
Re: Drivers 2.1.5 with Slic3r PE 1.39.2
So Shiny!!!
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Is it possible to add an option to append the estimated time to the filename of the outputted gcode? (object_1h_35m_15s.gcode)
I think it would be a great option for when you forget and can just glance over to the lcd and watch the filename and see the time appear.
Under the image is says "Run "Help - > Configuration Assistant" to apply the latest settings"
Do I need to run configuration assistant or just install the new version to my applications (macOS)?
It's been a while when we talked about removing ".gcode" at the end. It's obvious that file is .gcode, so it just takes precious space.
Is it possible to do that?
Prusa's Color-Print site doesn't seem to be able to handle any GCODE generated by Slic3r PE 1.39.2. Just sort of hangs and crashes after selecting a file, tried multiple browsers and some older GCODE and the commonality seems to be the latest version of Slic3r PE. I went ahead and dug into the details to just add the M600 command manually for something I needed, but wanted to share that it's broken.
I really want to upgrade to the new Slic3r but as stated in the previous post the gcode generated with 1.39.2 freezes up Prusa Color website. I also tried the 1.40 Alpha release and it does the same thing, I reverted back to 1.38.6 and have no problems with Prusa Color.
This is happening for me too. Any way to confirm PRUSA is aware of this and looking into a fix? I use PRUSA Color constantly in my work, so I'm really hoping this gets resolved quickly.
Thanks.
If I may suggest at least a temporary solution: you can use PrusaControl to do the same thing after loading an existing g-code 😉
Anyone having trouble with odd lines being added or omitted using 1.39.2? If I slice my model in PrusaControl, I get this:
But if I slice it in 1.39.2 and then bring it in to PrusaControl to add the color change, I get this:
I didn't try to actually print it yet. Do I have a setting wrong?
Interesting idea, I will suggest it to the devs 😉
I suggest running the Assistant as it will overwrite your stored profiles with latest ones, make sure you have a copy of them, if you customised them.
I wasn't part of the discussion, can you please share details? Extensions can be hidden in the system, but I don't think you can remove them.
Hi, yes we are aware, I already asked my colleagues to check the site.
Can you please start an issue at https://github.com/prusa3d/PrusaControl/issues ? Thanks
/ Knowledge Base
/ Knowledge Base
