downloadable 3d parts
yetanotheraccount
(@yetanotheraccount)
I just had a problem getting the filament to unload.  I finally managed it.  Along the way I decided it might be a good idea if some of the parts were in different colors so that I could identify what they were.  Supposedly there was/is a page that allows one to download those parts.  But when I click on it, I get 404.
So, are there downloadable parts or not?
Respondido : 10/09/2020 11:57 pm
jsw
 jsw
(@jsw)
RE: downloadable 3d parts
You should be able to get the .stl files for the pieces here:
https://www.prusa3d.com/prusa-i3-printable-parts/
Respondido : 11/09/2020 12:03 am
yetanotheraccount
(splutter!)  well, whatever happened, that's what I thought i clicked.
Doesn't matter, I have them now.  And I did notice the warning about using non-black colors, so I'm doing this at my own risk.
Thanks!
Respondido : 11/09/2020 12:14 am
sledjunk
(@sledjunk)
Does anyone know where to download the file(s) for the new style spool holder as shipped with my Mk3S?  I have found a number of holders, nut they are all single roll holders.  The closest one is on the MK3S page as 'B4', but it is a single holder in one piece and mine is actually 3 pieces, the main support and the two supports which clip into the main support.
I have printed all of the other pieces for my printer and this is all that is left.
Thanks
Drinking alcohol can cause memory loss. Or worse, memory loss!
Respondido : 11/09/2020 8:42 pm
jsw
 jsw
(@jsw)
There was a spool holder on the main printables page, but not sure if it's the exact one you want.
Respondido : 11/09/2020 9:15 pm
sledjunk
(@sledjunk)
@jsw
That one has two arms and holds the spool between them.  Thanks though.
Respondido : 11/09/2020 11:02 pm
keithywhites
(@keithywhites)
im looking for the original stl files for the early mk3.  before the s upgrade.  where can i find them?  mostly for the einsey case that used zip ties to secure the extruder wiring harness...
Respondido : 13/09/2020 7:11 pm
Posted by: @matthew-k18
You can find all the parts on the Prusa Github pages. You need to select the Mk3 from the little drop-down box at top-left.
Respondido : 13/09/2020 7:27 pm
