Does there exist a slicer that will let me pick a different infill pattern for layer 1?
For sure, slic3r and simplify3D don't offer it. However, there must be at least 20 other slicers out there. Anyone here know?
Re: Does there exist a slicer that will let me pick a different infill pattern for layer 1?
In slic3r you can select a part you are printing and go to settings (on the pop-up menu or toolbar). In the dialog box you can then click load generic and add a slab of an appropriate height. Select the resulting lambda-slab and click the green plus button below it. Select top/bottom fill pattern from the drop-down.
I've used this to make for example the bottom layer concentric and the top layer rectilinear.
Simplifed3D can do it.
Just setup a process for layer 1 and and a seperate process for the other layers.
Thanks! That is exactly what I want to do, and probably for the same reasons too.
