Dimensions with Multi Material Upgrade?
punkindrublik
(@punkindrublik)
Looking to build an enclosure for my new Prusa printers. They'll be here today, but my Multi Material Upgrades are still several weeks away. Can somebody tell me how tall the unit is with the upgrade installed? I want to make sure my new enclosure will clear it. TIA
Opublikowany : 22/03/2021 6:33 am
kpreid
(@kpreid)
RE: Dimensions with Multi Material Upgrade?
The tallest parts are the MMU-to-extruder filament tube, and the MMU filament sensor cable. With the extruder all the way up on mine, the filament tube loops up to 57 cm above the table. If you never print that high, you could get away with less height — down to 46 cm. Your exact dimensions may vary due to the parts flexing differently.
Another perspective: It's taller than a MK3 with an empty spool holder, but not as tall as a spool on the holder.
Opublikowany : 22/03/2021 2:33 pm
punkindrublik
(@punkindrublik)
Posted by: @kevin-reid
Thanks so much!
Opublikowany : 22/03/2021 9:17 pm
