Crash on the Y axis
John
 John
(@john-8)
Crash on the Y axis
I had to stop printing midway through a job to to some stringing. I manually pulled the sheet back to remove the
piece and left in that position. When I restarted I did a first layer calibration and I had a crash detection, on the Y axis.
Soooo, does manually moving the bed throw everything off? This is a mk3s+ preassembled, so I've got little experience in calibration.
I turned it off till I get some advise on how to proceed, Wizard? XYZ cal? what position should the bed be in? manually moving it a no,no?
I don't want to make thing worse.  Thanks john
Posted : 18/02/2022 1:05 am
RE: Crash on the Y axis
Moving it by hand shouldn't do any harm unless the stepper motors are engaged but in that case, you'd know immediately that it's bad idea. I'd re-do the calibration and see if that fixes it.
Posted : 18/02/2022 11:52 am
John
 John
(@john-8)
Thanks I found the culprit, a little wire on the real left end was getting under the plate. I did the wizard
and all seems to me ok,,,except the first layer which I'm working on.
Posted : 18/02/2022 9:48 pm
