Cold nozzle unload
RacOutlaw
(@racoutlaw)
Cold nozzle unload
If it is built into the gcode as you can see in terminal where it will not do cold extrusion when loading filament why not have it where it will not try cold unload.If your printing and it fails so you do a cancel on the print,so the filament is still loaded and then you decide to to restart print after cleaning off the bed with filament number 2 instead of number 1 it will try and unload 1 while still cold. Can it not be setup to know that when the filament sensor is triggered to do a heatup first then unload. Have it pop up asking if its pla or petg that is loaded or something..?? just asking as  sometimes  i forget to manually heat up unload then start print..
Napsal : 10/02/2021 8:59 pm
