Can warping be solved with higher bed temperature?
sledgehammer
(@sledgehammer)
I think there is a spot on my heated bed where my 3d prints (always) warp or even come loose (even with brim). I will check it with thermal camera (later) to see if it is still heated but in the assumption the heatbed is OK, can I solve warping/sticking with a higher bed temperature (printing with PLA)?
The glue (that came with the printer) helps but is a bit messy :p
Mario
Respondido : 12/01/2021 3:45 pm
RE: Can warping be solved with higher bed temperature?
Hi Mario,
I think you may be using a Sledge hammer, to Crack a nut...
Glue stick is provided to reduce adhesion for PETG Prints
I don't use any of the other surface treatments, no IPA, No Hairspray, No Magigoo, No Painters tape, JUST CLEAN Prusa PEI sticker, or Clean Prusa Powder coat.
occasionally I need to add a Mouse Ear, on something that is Pointy   (Sharp corners tend to lift) these blue mouse ears are 5mm diameter, 0.2mm thick. in this case I am using a Prusa Textured sheet.
PLA 'Should' Bond well to a prusa build plate without need for any other surface preparation apart from being clean and contaminant free...
I make sure 7x7 Mesh Bed levelling is turned on,
(LDC Menu option under "Settings>Mesh)
then I take my build plate to the kitchen and clean it very well with Hot Water and a touch of dish soap (Basic Dish detergent, like Dawn or Fairy liquid)
I rinse well, and dry with plain paper towels, then I do not touch the clean surface with my fingers...
I use 'Life Adjust 'Z' My Way'
to set live Z (In preference to the Prusa first layer calibration tool)
then when I slice my own files, I set the heatbed to 65C or 70C
Respondido : 12/01/2021 6:17 pm
Matto
(@matto)
@joantabb
Do you use something THAT abrasive on the build plate?
Stock Prusa MK3S+ built from kit on 12/2020
OctoPrint, typically print from a drybox, no enclosure yet
Printing proudly since 2011
Respondido : 12/01/2021 7:47 pm
@matto
Hi Matto, Some folk use 1000 grit wet and dry paper, I generally use the yellow side of the sponge,  the green side doesn't appear to damage the powder  coat if you do use it...
Respondido : 13/01/2021 2:55 pm
1 les gusta
