Can I recover this days old print job?
kvdental
(@kvdental)
got a mintemp error, which stopped the print.  I see the Z axis number on display, is there a way to find the x y numbers?  I plan on editing the gcode to startup again, once I figure out the mintemp issue.  I use prusa slicer.  Thanks for any info👍.
Respondido : 31/01/2020 12:32 am
Nikolai
(@nikolai)
RE: Can I recover this days old print job?
You can try with M114 command.
Alternative mode is to go to the menu and move the axis. Once you start moving, it will display you the value. Move forward the backwards should give you the current position.
Anyway, as you will replace either the extruder or bed cables, the restart from the current position is pretty advanced. I would recommend just to start over.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 31/01/2020 1:27 am
toaf
 toaf
(@toaf)
a small chance just unplugging it and plugging it back in might start it up also.
Respondido : 31/01/2020 2:17 am
CallXYZ
(@callxyz)
Is this going to be Godzilla?
Respondido : 31/01/2020 7:13 pm
kvdental
(@kvdental)
Yes it's Godzilla.
Thank you for the replies and suggestions.  I was able to edit the gcode to finish printing.  Luckily the mintemp error went away, but I know I'll need to address the wiring later. Slight layer shift, but fixable.
Respondido : 01/02/2020 8:46 pm
rmm200
(@rmm200)
Color me impressed... Good job. I thought it was a goner.
Respondido : 01/02/2020 9:55 pm
